f1racer328
You could probably replace it with an AMK and flash the new firmware with your GAP tool.The front and central valve blocks were serviced with new o rings. There was quite a lot of desiccant dust build up. Still need to do the rear. My gallery pressure is building into the 170’s psi range. What should it be? It’s probably the compressor. Who knows has a good source on the oem hitachi?
JD
