Anyone have Tactical Rover Sliders?
jwest
Seattle WA
Sorry, such a long day dealing with it that I never took a photo....
jwest...when you talk of "modifying the bracket" are you referring to the bracket that the AMK compressor comes mounted to? ...or are you referring to the Tactical 4x4 re-location bracket?
jwest
Seattle WA
T4x4. basic mild steel painted black. perfect for rusting quickly especially after cutting it to work.
My amk came with a heavy aluminum bracket which would be awesome to modify itself...and I plan to look into that at some point using the reworked t4x4 as a template. It's snug under there though so the benefit of the 1/8" plate t4x4 is it's thin fitting clearance.
So cut new holes, 1 cm left of the original three mounting holes, maybe prime it with some rustoleum and that's all she wrote?
The holes are right on the bend of that angle bracket so it would be tough to lower them (to raise the compressor).
jwest
Seattle WA
What I cut in the holes area was mostly the slot in front of the bottom 2 holes for bolt access so that I could thread the bolt and also tighten/loosen them from below all the way out or in.
Yes, I could see that and plan on doing that to the relief slots as well. I was thinking of turning the holes into slots that would run horizontal (if you were looking at it positioned with the single hole on top) so that the entire assembly can be moved FWD. Maybe 1.5 cm is about all I could do. Not much edge margin on that top one.
