jaguardoc504
- Joined
- Feb 10, 2014
- Posts
- 420
- Reaction score
- 100
Has anyone else had a failed rear ABS sensor?
I have had an intermittent issues with the LR4 basically becoming useless.
No ABS, TC, DSC, TR, and suspension sitting on bump stops.
At first I was told is was the battery by the dealer. It was replaced less than a year ago, so it was replaced again under warranty.
Everything was great, until 2 weeks ago, when I got a repeat of the failure multiple times.
Sucks be out and about with the family while on the bump stops.
When I pulled the codes I kept getting the same "Left Rear ABS Sensor erratic signal" fault.
I passed this information along to the dealer, including the log from my IID tool showing the 0 speed indication the Left Rear Sensor.
They insisted it was the alternator not charging the battery, causing weird signals from the sensors. If that was the case, why am I not getting weird signals from all of the ABS sensors or any other sensor for that matter. I was an ASE Certified Technician with JLR (Woburn Jaguar, and Land Rover of Peabody MA) for over 6 years, none of their conclusions made any sense. But it is the winter and I just don't have time to properly diagnose my own vehicle. They assured me they had done a current draw test on the alternator and it was weak but not INOP. So this COULD cause an intermittent failure, or could not charging the battery all the time. Yeah sorry thats not how an alternator works on our LR4. Because of the way the computer balances the battery and alternator depending on the load requirements and the need to extend the battery life if possible, a "weak" alternator would not even show up. Either it would be dead, or no issue at all.
Given how easy it is to change the rear ABS sensors, I ordered one. Hopefully it will be here tomorrow (with our 2' of snow coming down today...).
I'd rather try a $40 dollar solution and fail. Than a $1000 solution from the dealer, which I know is wrong.
