Camshaft Position Sensor Code P0390
BBLR3
I recently recently replaced my drivers side valve cover gasket myself. Test drove right after for about 15 min with no CEL. Stop off at a store and come back out and now there was a CEL. Code reader said P0390. Could not find anything on here for that specific code, but online I found: Camshaft Position Sensor B circuit (Bank 2). I assume its one of a couple sensors behind the thermostat, just not sure which one. If I have to pull the thermostat, maybe I just replace all the sensors there and then do the rear coolant manifold to since the coolant level will be down. Any other gotchas for replacing them?
Edited to say other than the CEL, it runs completely normal. No limited performance etc...
Rover Range
Texas
Cam sensor failures are extremely rare.
I would check the related connectors at the front of the engine. Make sure no coolant in them and properly seated.
BBLR3
I checked connectors when I got back home (removed, inspect, reseat) cleared codes and it came right back. Everything appears seated and not loose. I guess Im just lucky :)
BBLR3
I'll see if there is enough slack in the harness and swap connectors. See if the problem follows.
Rover Range
Texas
Sensors are the same. Just swap the sensors.
You don't want to swap connectors, this will generate different DTCs.
