2008 TDV8 Fuel Pump - No Fuse/Relay ?
KevinHDKent
Herne Bay UK
Hi,
New to the forum, new to Range Rovers.
Appear to have a lift pump issue not supplying diesel forward to the engine bay.
First stop fuses & relays.
But where, if there are indeed any ?
Can find no mention in RR literature, and no description or image on line match that on my vehicle ?
It’s a 2008 Td V8 3.6
Do you have an owners manual? Normally fuses and relays are located by the battery and under the dash on the passengers side of the vehicle.
KevinHDKent
Herne Bay UK
I have the owners manual.
Fuses are in the lower glove box (passenger side) and in the rear compartment behind the wheel arch on the right.
None of the fuses are noted as protecting the fuel pump.
The relays are not identified on the manual, and the icons in the vehicle do not indicate fuel pump.
Fitter14
Staffordshire
KevinHDKent
Herne Bay UK
Thank you for that.
I have now found the fuse/relay compartment in the engine bay (not noted in the Owners manual !)
and will take a look now.
Any ideas on a relay fir the lift pump ?
KevinHDKent
Herne Bay UK
I’ve checked engine bay, and all the 25A fuses.
But the fuse legend you show has 30 fuse positions, mine only has 20 ?(as photo)
So can’t be certain what I’m checking .
helge
