Adding Rear Diff Motor
JangoSW
Chicago
Hello,
Saw this on Amazon. Couple guys said it works Anyone try adding these motors?
Thanks,
Sean
Stuart Barnes
Los Angeles
Im waiting on a replacement from another online retailer.
This is the code the IId tool picked up.
P186D-97 Clutch actuator stuck - Component failure. Component or system operation obstructed or blocked
For reference the car lowered for safety, looks like its on the bumpstops or close to it and the abs, hdc, and suspension have all thrown faults.
Once I get the old one off I'll take it apart and see what's stuck.
Stuart.
JangoSW
Chicago
Stuart.
My LR4 did not come with a rear diff. Can you add one to a vehicle that was not equipped with it? (LR4 2002)
To the OP: are you asking about adding just the motor for the locker or the entire new diff? I'd be wary about buying a part so vital off Amazon without knowing the part number and compatibility.
Idaho
Looks to me like it might be a no-name/off-brand replacement motor for models with optional locking diff.
If you are asking if this will somehow upgrade your non-locking diff to locking... nope.
o_O
JangoSW
Chicago
o_O
So you need this piece and the motor?
Differential Assembly - Land-Rover (LR041063)
scott schmerge
Charlotte, NC
and a whole lot more...all the wiring the control module, etc. I think someone did a write up on here of a conversion using a diff off of a parts truck. Not a plug and play.
helge
