tranny shifting rough
simjet22
And best of all, IIDTool can override your EAS (Electronic Air Suspension) to give lift at any vehicle speed while offroading.
Highly recommend this device! +1
That's whats up! Btw since you brought up the EAS....is there any general maintenance needed with this system?
Surfrider77
Nothing special that I know of. The IIDTool simply (electronically) alters the data of the default height. I have mine set to raise +45mm. This is +45 over each of the stock (Normal, Access Height, Off-Road) heights.
Once I am finished off road, I simply use the tool to load up the defaults. Takes all of 30 seconds to swap to and from your custom settings.
