Thermostat Replacement and then some.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
I decided to do the whole 9 yards. I want to keep this vehicle forever and even if the parts are ok now, 89k is a good time to replace with that long term goal. If I was only keeping it another 50k, I would take the cheaper route. I am recording this, might eventually end up on UTube.
I ALWAYS tell people that once you have a coolant leak, you should replace everything. Most parts are plastic and deteriorate over time and as soon as 1 part goes, the rest will follow suit over the next year or so. Might as well do everything at once and take the worries out of it.
Here's what I posted for someone else that's going through the same thing... I'm sure you'll find better pricing if you shopped around.
ALL OEM Parts!!
Water pump ($225) - https://www.autohausaz.com/.../128504_20_5824_1__7_6-RV...
Water pump gasket ($26ea) - https://www.autohausaz.com/pn/11879...OV1dsku7odkrejHDiHmUc3-xP2x08vzhoCI8wQAvD_BwE
Oil cooler tube ($25) - https://www.autohausaz.com/.../118793_20_3842_1__5_8-RV...
Front crossover pipe ($127) - https://www.autohausaz.com/.../118793_134_3842_1__5_8-RV...
Rear crossover pipe ($127) - https://www.autohausaz.com/.../95999_134_3842_1__5_8-RV...
Thermostat ($98) - https://www.autohausaz.com/.../136928_134_5824_1__7_6-RV...
Coolant ($28ea) - https://www.fcpeuro.com/.../land-rover-engine-coolant...
Water pump $225
Water pump gasket $52
Oil cooler tube $25
Front crossover tube $127
Rear crossover tube $127
Thermostat $98
2 gallons of coolant $56
= Total $710
Knowing you won't be stuck on the side of the road, because of overheating, priceless! You’ll also be good for another 100k+ miles.
FCPeuro.com has lifetime warranty and may have better pricing on certain parts.
If it was me, I'd completely flush out the coolant till it's clear and swap out to dexcool. BTW... that's what I did over 5 years ago. My cooling system has easily gone over 75k miles already without any issues (knocking on wood).
