ProTonez
I'm on 275/55 with rods and a VERY faint rubbing at near full lock. Haven't decided if it's even worth trimming at this point.
Ah, I must've overlooked that, sorry. Reputable tire shops are perfectly fine. I actually refuse to go to the dealer for any tire related stuff, simply because my local tire shop is excellent and charges much less. I'd just ensure that your tire shop has/uses a touchless tire mount machine.
The TPMS system isn't all that sensitive, so I wouldn't be worried about TPMS issues. The tire pressure indicator may come on after they're mounted, but that'll disappear shortly after driving down the road.
Ryanji, would you know how to establish this more precisely? There is this chart that helps (below) but it doesn’t account for tyre width, and it doesn’t contain any tyre that would fit on a 18” but have a diameter of 31”...You can probably go up to around a 31 or 31.5" diameter without rubbing. The wider the tire, the closer to 31 you'll need to go.
A "lift" is not required with either.
Thanks Crash,
I'm going to go for the Grappler G2 for sho. I'm still mulling over the 265 or 285 just because i never did this before and don't want to fudge things up. I will inquire about the touchless mounting machine as well. I will keep you posted (no pun intended). Thanks again!
