Abram
Hi again LR Family, I've got a new round of errors I'm trying to sort out, and I'm researching old posts here to see if I can find similar issues. Apologies if I'm creating duplicates.
2012 LR4 - 5.0 V8
To start with the most pressing: The parking brake. I use the parking brake every time I stop driving the vehicle, so it is exercised regularly but yesterday afternoon it suddenly started taking multiple presses of the lever to release (though it would consistently engage with one pull of the lever). Today it happens to be about 10º warmer than yesterday (about 90ºF) and when I was about to head out my truck never "settled" after starting and letting it idle as I always do (I wait until it has settled to about 5-600rpm), it never dropped below 1000rpm even after sitting for a couple minutes, and then when I went to release the parking brake it errored out and triggered a fault, U2002-92 (68) Switch general electrical failure - Component failure - performance or incorrect operation. I shut the engine off and turned it back on and idle went back to normal and the brake was disengaged. I'm concerned the EPB is about to crap out on me, but I'm trying to figure out if some signs I've seen have been warning me of this. After replacing my wheels and tires, I noticed that when I would activate the parking brake the truck would still have a bit of movement and never really felt like it was "secure". Additionally, since purchase, the truck will often squeal when braking in reverse, but never while driving forward. I also get a pulsing vibration in the truck when slowly releasing the brake from a full stop or when slowly coming to a full stop and I don't know exactly if it's related but I do see fault code U0421-68 (28) Invalid data received from ride level control module - Algorithm Based Failure from the ABS module. (See my previous thread for the details). Are these connected? The brakes were serviced a few months prior to my taking ownership last December.
Additionally my air suspension has been intermittently giving me a fault, particularly when trying to use access height, but every time if I just shut off the truck and turn it back on I can reset it and use all three heights again (I'm not running Johnson Rods or any sort of lift via my IID tool), it's triggering fault C1A13-64 (2E) Pressure does not decrease when venting gallery - algorithm based failure, and because I don't know the intricacies of these systems yet, it sounds to me like these are all somehow linked together.
Is there any possibility this is related to the battery? The voltages seem ok (12.6v when off and 14-14.5v when operating) but I have no idea how old the battery is. The reason I ask is that my driver and passenger doors are also intermittently triggering central door lock codes (though they've never not locked/unlocked as of yet) so I'm curious if maybe the battery is just wearing out and it's triggering other problems. I'm sorry for my lack of knowledge, trying to learn as I go and read up on as much as I can. I always appreciate any guidance offered. I do have a workshop manual that I've received via this group but I admit my mechanical knowledge is limited and I'm still very much a novice here.
2012 LR4 - 5.0 V8
