navigare
I even have a 285/70-18 on mine now but because i'm not using spacers, it tucks inside the rub range - even though just barely
For looks though, 285/60-18 is so cool, even more if using a 25mm spacer. I admit it is so hard sometimes to leave things how they function best vs being swayed by how cool it looks![]()
Thanks, jwest, that is very helpful. But if you say 285/70-18, that’s with rods or other mods, right? Even though the wells on your LR3 are apparently 0.5” bigger than on my LR4… Myself, I won’t pretend to have no regard for the looks
Btw., is the sun roof on LR3 not the same size as on LR4? If so, then I have crawled to the RTT through mine, although admittedly, I’m only 5’8 and 32” circumference
And, there is a solution for scratches on the roof (and elsewhere) - protective film! XPEL even have pre-cut sets depending on model year and engine version. Costs a few hundred but well worth it when done properly - especially the front of the car. You can put thinner one on the sides and rear… I’ve had mine for two years now, been in all weathers, washed it, scratched it - and it’s GREAT!
