LR4 Technical Service Bulletins (TSBs)
As owner of a Range Rover Sport since 2005, I have collected the majority of TSBs for that model for the past 7+ years. I have arranged them in a directory similar to what Land Rover uses on its technical web site (TopiX) here:
https://www.box.com/rrs
Please sort them by name rather than the default - by date - as they are much easier to search that way (bulletins are issued in numerical order.) The listing should include all TSBs issued for the RRS from 2005 and up to 01/13.
Although these are for the RRS and not for LR3 and LR4, the majority of bulletins are shared between the two models given their many similarities, so I figured I'd post the link here as well for future reference.
Edmo
what mileage does the front brakes get changed and does this normally include rotors....
Quijote
Metro Boston
You don't change brakes based on mileage. Instead you check them for wear. The pads can often wear faster than the rotors so you may only have to change pads. They need to be inspected.
My LR4
Any problems for by an error message , hood open , but it's not open and can't lock it in 2012 LR4 LUX .
LR34
You probably already fixed it, but my LR3 had the same issue. It was due to a stuck hood latch sensor under the hood. The hood shut fine, but occasionally the alarm would go off or car would beep when trying to lock doors. I think it was a $20 part.
Oops, did I say hood, I meant bonnet. Here is an ebay link to the sensor:
http://www.ebay.com/itm/Land-Rover-...heft-Hood-Switch-Sensor-Genuine-/230860305950
LR4-RIO27
very interesting thread... learning a lot, my brother just replace his pads and rotors due bad pads
Jomalo
help
Just had my rear brakes replaced, bought the car used at 15K miles (2012 LR4) - had the brake noise issue at 16K, dealer covered the cost of replacing the rear brakes. However, I'm still hearing the noise (rotating squeak noise, as if an indicator was hitting the rotor - car was re-inspected and we couldn't find out why)... any advice? Could it just be weather related?
Also, I haven't searched for it yet but anyone dealt with roof leaks/wet headliners?
Also hearing a plastic vibrating noise that seems to come from the center console?
Lastly, fuel indicator goes up or down depending on the angle at which the car finds itself..
