LR4 Logic7 Sound Upgrade
gaz_0001
Middle East
Cut the connector off, and wire direct.
If you are not going to install an uprated amp, then go with the Pioneer, it's a bit more efficient.
You will need to make an adapter plate for it to fit properly. I made mine out of MDF.
I am replacing mine just now and searching for a new sub.
Can you tell me which model pioneer you replaced it with?
Or even what OHM the replacement needs to be? Is it Dual 4 OHM?
Thanks
