LR4 - Coolant Under Pressure When Cold
gillygong
Pasadena
Which relays/fuses do you pull on the 5L v8 to do compression test? I need to test just cylinder 5 since I have an ongoing misfire on that cylinder that I'm trying to diagnose.
RoverTide
Memphis, TN
I pulled the two in the engine compartment in the fuse box next to the battery. Both had the gas pump symbol. One is a relay and the other is a fuse.
Hamman
