- Joined
- Jan 6, 2006
- Posts
- 3,948
- Reaction score
- 261
I feel like I've read a similar post on this board or another....a while back.
Does anyone know if the part numbers are interchangeable? I have a ucb500072. Am I able to replace this withe a ucb500071? or an ucb500070?
I replaced my ucb500070 with ucb500072, so I'd say they are interchangeable. I had the same issues, no codes LR3 acted like command shift didn't exist. I went through all the forum, tried everything and nothing worked. Finally looked at the wiring diagram for the vehicle. Go underneath the vehicle on the passenger side right above the gear shift linkage you will see a wire bundle that plugs into the transmission for the TCM I think. Pin 1 is the very top wire, it controls the sport/manual mode of the vehicle. I undid the connector and inspected it. All was good. Reattached it and wiggled the wires a bit. That solved my problem. I suspect its just bad wiring connectors on Land Rovers part. Go under and wiggle that wire bundle, make sure you try to wiggle the very top one. I suspect that will probably solve the majority of issues everybody has with the sport/manual (command shift) mode.
