H7 LED or Halogen Fog Light Bulb Recommendations
gsxr
Big Sky Country
If you use your lights where it snows and it is snowing (particularly the fogs) then leds are almost useless as they get covered quickly and don't produce enough heat on the surface lens to stay clear. It doesn't happen often but same problem with led low beams.
That's a great point - hadn't thought of the snow/ice issue. I'll have to look into higher-output halogens for the fogs next!
Ryan, thanks for the reminder, I will buy another pair of the H9's to leave in the glove compartment! At least until I spring for the HID's.
:2in1:
