Electronic Parking Brake (EPB) failure
sonicpix
Ontario, Canada
My EPB also is screeching. I took my LR3 into the mechanic to replace the upper control arm and bearing. In the process he cut the brake line and replaced it. But when I got the truck back the suspension was dropped. It never came back up and I got a suspension fault error on my dash. I went to look at the wheel for anything obvious, but when I tried to engaged the EPB it squealed and gave parking brake error codes.....first the red, then the amber when I tried to disengage it.
I read the UK forum posted here and it looks to be like an adjustment fix. But....would this cause the vehicle to drop and throw suspension code errors? Thanks
2006 LR3 HSE 262k km
sonicpix
Ontario, Canada
UPDATE: The squeal was just a minor adjustment, and i had them clean up my emergency brake cables for $190. Didn't fix my suspension faults.
