Coolant Crossover pipe (outlet tube) for SCV6 LR4
Waterndirt
Mine went at 52k or something silly
Thats just not right. Its so common, on my last visit before my warranty expired, my service tech pressure tested my coolant system just to check to see if anything sprung a leak.
Azoo
Brampton Ontario
Just had my water pump and crossover pipe done at the stealership, below is my invoice for the job.
J# 2 16LRZZPTEST PRESSURE TEST SYSTEM HOURS: 5.20 TECH(S):108 925.60
COMPLAINT: LOW COOLANT LIGHT COMES ON ALL THE TIME OWNER HAS TO KEEP
TOPPING UP THE RESOVOIR
CAUSE: WATERPUMP AND COOLANT INLET PIPE LEAK
CORRECTION: REPLACED WATER PUMP, COOLANT INLET PIPE, FILLED AND BLED
COOLING SYSTEM, ROAD TEST, CHECK FOR LEAKS, COOLING SYSTEM
OK.
PARTS------QTY---FP-NUMBER---------------DESCRIPTION---------LIST PRICE-UNIT PRICE-
1 PKLRWP5.0 5.0L WATER PUMP **** **** ****
1 LR028136 TUBE - OIL COOL 29.99 29.99 29.99
1 LR030593 SEAL - OIL COOL 10.06 8.45 8.45
1 LR097165 PUMP - WATER 355.56 355.56 355.56
1 LRN2279 FLUID - COOLING 32.99 32.99 32.99
1 LR018275 TUBE - WATER OU 77.99 77.99 77.99
TOTAL - PARTS 504.98
JOB# 2 TOTALS------------------------------------------------------------
LABOR 925.60
PARTS 504.98
JOB# 2 JOURNAL PREFIX LRCS JOB# 2 TOTAL 1430.58
Suby555
Massachusetts, USA
OK.
LABOR 925.60
PARTS 504.98
Thanks Azoo. The difference between ours, is i think i need to remove my supercharger to get to the water outlet tube.
Ive been playing around with it, and am a competent DIY mechanic, but i think at this point im putting it back together and getting it trailer-ed to LR to get sorted. :(
CoastieLR4
Cape Cod, MA
Did you end up figuring this out? I have a 16' and had coolant in the valley as well. Mine appears to have been the oil cooler seals. So far the valley is dry.
I do have a leak around the thermostat I'm trying to chase down though. Mine happened at 41k miles..
