C1A20-64
CyberTiVo
US
Getting fault C1A20-64; plenty of posts related to earlier models; anyone know which compressor the Disco5 uses, where it's located, air tube diagram or distro block location? Either a leak or compressor going bad, my guess is leak; would like to soap fittings or rebuild block before blindly replacing the compressor. Just need to know where to start looking; I'm sure it's all hidden
remember5
Not where I would have been looking. LOL...
CyberTiVo
US
Thanks, I did find it, right where you showed! It is an AMK model and it is single unit with the cover rivetted on; definitely not designed for self help; I drilled the cover off only to find another box riveted also; there is a plastic elbow that looks like it could be a small dryer that's cracked, labeled DA4053 11505; the Google knows nothing about it; going to plastic weld the crack when it can sit for a couple of days to fully cure; I'll report back
CyberTiVo
US
Once I got it out, I noticed AMK 110366 & PA66-GF30 stamped in the plastic; the latter seems like the type of material and Google knows nothing of, what looks like, the part number. Based on other markings on the assembly the above is correct.
remember5
It may be old but we're still alive and kicking. I still haven't pulled the trigger on a D5 but my LR3 is getting ready to roll over 260k miles. :)
