Beep beep
Longtrail
Ann Arbor
Page 4210 of the Manual has this:
CJB = central junction box
It sure seems there are a lot of Antennas! I'm thinking that the wiring diagram should have something in terms of the wiring but I'm not sure if this will help with the location of the antennas?
Yesterday I had the key in my hand, my cellphone in my pocket and still get the beep beep; I moved my hand ever so slightly and then the doors locked! It's annoying!
CRYA
Napa Valley
Do let us know if you find em all! I get remote hijinx more than I'm comfortable with and every time I'm off-road, I have to push to the far back of my mind what happens if the truck decides not to detect my key for starting...
Longtrail
Ann Arbor
This is what satellite cell phones are :)...
I'd make sure I know how recovery with the key works, I think you have to put it under the steering wheel or something like that!
Will keep you posted via this thread but this is also a low priority one for me!
TimVZ
Iowa, USA
If the battery in key fob fails, there are three raised lines on the bottom side of the steering column. Hold the key fob up against these three lines and the key fob will be sensed and allow vehicle to start (even with no battery in fob).
ftillier
Portland, OR, USA
That's a good point - pull the battery out of the FOB and see if you can sort out how to get into the car and start it.
CPalacay
Woodinville, WA
I’ve been dealing with this issue too. It’***** or miss when it occurs, but when it does I just put my gym bag close to the door handle and the doors locks without any issues. It’s annoying, but not at the top of the priority list.
Really interested to know what you find out. Good luck!
-Christian
Longtrail
Ann Arbor
-Christian
That's exactly how I feel, sort of annoys me but doesn't quite reach the top of my very long list! I'll keep posting here but this is a slow burn issue for me as well. Next job is viscous cooling fan as I'm getting an electrical fault!
KingArthur67
