ARB winch bumper need hardware / mounts / brackets.
Annapolis, Maryland, USA
decide if I want to go down this road or hang it on the garage wall as a decoration. ;)
Build a small semicircular bar in your garage, and use the ARB as the footrail. A couple of tall stools and some beverage inventory and you may never leave that area.
Well, worst case scenario, even if you have to spring $700 for the brackets, you're out a total of $1200, which is still a decent deal so long as the bull bar is in decent condition.
Toothbob
Chattanooga, TN
So I did go ahead and order the install kit from ARB. Looks to be very complete. It's expensive ($723) and will take forever to get here (3-4 months). I'm going to attach below the list of parts that comes in the kit just in case anyway else needs to go down this road in the future.
Material Code 6173647
F/KIT MAIN 3432210
# Code..Component......Description Qty
1 s3758124R IMPACT ABS ASSY D 1
2 s3758124L IMP ABS ASSY DISC 1
3 s6542109 TRAY STONE DISCO 1
4 s6542110R TRAY STONE DISCO 1
5 s6542110L TRAY STONE DISCO 1
6 s3758045 BRKT FAIRLEAD COV 1
7 3162468 INSERT FOG+INDICA 2
8 s3756801 BRKT ASSY WASHER 2
9 3162470L BUFFER 260X230 UP 1
10 3162470R BUFFER 260X230 UP 1
11 6821287 LAMP KIT LED|INDI 1
12 s6173648 F/KIT BAGGED 3432 1
1 s3758046R BRKT FOG LIGHT DI 1
2 s3758046L BRKT FOG LIGHT DI 1
3 s3756778R BRKT COVER MNT (R 1
4 s3756778L BRKT COVER MNT (L 1
5 6151357 SCREW SEMS HXHD M 4
6 6151204 BOLT HXHD M10x1.5 14
7 6151321 NUT FLANGE M10x1. 14
8 4581040 WASHER FLAT M10 x 16
9 4581048 WASHER SPRING M10 18
10 6151304 NUT CAGED M10 3.3 4
11 6151022 BOLT HXHD M8x1.25 8
12 6151021 BOLT HXHD M8x1.25 6
13 6151262 BOLT HXHD M8x1.25 2
14 4581044 WASHER FLAT M8X17 18
15 4581045 WASHER FLAT M8X17 2
16 4581046 WASHER SPRING M8x 12
17 4581047 WASHER SPRING M8X 2
18 6151301 NUT CAGED M8 3.3- 6
19 6151213 BOLT HXHD M6X1.0X 30
20 4581082 WASHER FLAT M6x20 30
21 4581287 WASHER SPRING M6X 26
22 6151128 NUT FLANGE M6x1.0 16
23 6151300 NUT M6 CAGED 2.6- 24
24 6151132 NUT FLANGE M8X1.2 2
25 BLB850 BATTERY LEAD 850M 3
26 6151074 BOLT HXHD 3/8 UNC 2
27 6151073 BOLT HXHD 3/8 UNC 2
28 sCR08 SPIRAL WRAP 350 M 1
29 6151309 NUT U #10|TZP480 6
30 6151317 SCREW PHD 8Gx18x5 8
31 6151308 SCREW PHD 8Gx1|TY 4
32 180302 CABLE TIE 4.8X200 16
33 3162152 CAP CB AERIAL HOL 2
34 s6191009 FLARE COVER TRIM 1
35 s3756499 BRACKET CONTROL B 1
36 3789223 F/INST 32/3432210 1
37 6821230 GROMMET 15MM ID 4
38 4581288 WASHER FLAT M10X3 6 0
39 6821169 GROMMET BLIND 8MM 4
40 665044 3M PRIMER 94 (AMP 1
41 6781437 TAPE 3M 2.3MM VHB 1
42 3163091 PLUG BLANKING BLK 4
43 6821189 GROMMET RND FL 15 2
44 6151384 SCREW ST PHD 5.2x 2
45 211127 BAG PLASTIC BOLT 1
46 6821116 GROMMET NYLON SQU 4
PanKyiv
