Alarm trigger/ Swithch off
Houdini
Hello,
I have a reange Rover HSE 2004, the alarm just goes off intermitently, how can I set it ti silence mode? Sio that it will only blink instead of blarring the horns.
Regards
Houd
Not sure it is possible. Call a dealer and ask... questions are always free.
oakley-mra125
Are you sure the truck isn't moving, causing the motion sensor to trip. I discovered a EAS leak because every night around 3-4 am my alarm would go off. Turned out the suspension would sag suddenly when the air temp got cool enough. Both fgront bags had small leaks.
Try disabling the motion sensor and see if the alarm still goes off. FYI you disable the motion sensor by hiting the lock twice, the red light on the mirror will be solid.
good luck.
It is not possible and sure wouldn't do you much good to just flash.
Why not fix the problem and and keep the alarm.
Exactly when does it go off, does it go off when you have a window cracked?
huelsmma
I know this is the RR forum, but I had a similiar problem in my LR3. Just once it has gone off without anyone around it at like 1am and freaked me out. That was 1.5 mos ago and hasn't happened since. Anyone know what this could have been?
Sinepgib
