acceleration problems
D
DIESENG
i have a 1997 disco 300 series 2.5 tdi automatic ,when you put you foot down to accelerate it jerks like it is running out of fuel ,it doesn't do it all the time .fault code reader has no fault stored ,i have checked most of the system i.e the needle lift sensor ,crank shaft sensor ,the edc actuator .the only things left to check are the accelerator pedal position sensor and the turbo dump value ,does anyone now how to check 2 ?
Slam
You might be able to find some help from the manuals. Try going to the resource page and typing in "manuals" and you might find what you are looking for.
RoverChic
I love Ryan and Rovers
Jamie I have the Rave CD (which will cover your Tdi). PM me if you want some of the pages from it e.g. the turbo dump valve.
Melissa
