2014 range rover - water on rear carpet - how? fried my audio amplifier
MIKE 1
When I open the rear passenger doors, there's water on the carpets. How?
How to fix? I had the two drains holes in the sunroof tracks blown out with
an air hose. Any ideas?
jlglr4
Northern California
Other than sunroof drains, the only places that come to mind would be the passenger door window seal, the door seal at the bottom, and maybe some other leak (e.g., gasket) on the sunroof (this type of leak would likely stain the headliner).
Have you had water in the passenger front footwell before (I realize you now seem to be talking about the rear footwell)? I’ve seen reports of the drains actually becoming disconnected in the area near the passenger footwell, in which case blowing air through wouldn’t solve anything.
If you blew out the drains with an air hose you may have caused them to disconnected them from the drain pan.
