2011 LR4 HSE $15,000
mmbirtcher
Description:
Located in Ballwin Missouri (St. Louis area).
For sale. Fully maintained and in excellent condition. Used as daily driver and on some longer dirt road overland trips to MT, WY, CO, and other places. Never off-roaded “hard”.
  • Impanema Sand color with tan interior.
  • Melville & Moon seat covers (leather is fine underneath)
  • GOBI Stealth full rack with removable sunroof panel, awning brackets and rear ladder.
  • TuffAnt 18” Steel Wheels (5)
  • Cooper Rugged Trail AT tires
  • IDCore Bluetooth CarPlay and Android auto installed.
  • Leather seats are the LUX Windsor style.
  • H8 AGM battery (biggest that fits)
  • Console fridge from RR Sport added.
  • LR headlamp and tail light guards.
  • GAP IID tool included.
  • Full LR pdf service manual included.
Service and maintenance notes- 2nd owner. Oil changed every 5k since born. New front LCAs. New manifolds. New valve covers. Newer parking brake module and complete rear brakes. Spark plugs last year. All fluids changed multiple times since new. Timing chains original and tight. Air suspension original - never sags or runs compressor too much nor is battery ever low in the morning. Garaged most of its life and currently.
  • Front passenger headlamp cover broken. These can be DIY replaced with a part from Powerful UK.
  • Some hood chips and very light pinstripes (invisible when waxed)
  • Some bumper scuffs from parking lots
__________________
mmbirtcher
mmbirtcher
115,000
  • Exhaust Manifolds
  • Front Lower Control Arms
  • Alignment
  • Serpentine Belt
  • Oil change Mobil1 EP 5/20
  • BG Engine Performance Restorer
  • BG 44K Fuel System Cleaner
  • Tires Rotated
  • Front differential Fluid replaced
  • Transfer case fluid replaced
114,000 2023/06/01
  • Wiper Blades
112,194 2023/01/27
  • Valve Covers replaced
  • Coolant Expansion Tank Hose replaced
  • Degrease Engine
110,324 10/31/2022
  • Right CV Axle replaced
110,218 2022/10/28 $2064
  • Parking Brake Module replaced with cables
  • rear brakes replaced
110,000 2022/10/27 $205
  • Oil Change Mobil1 Extended Performance 5/20
  • Engine Air Filters
110,000 2022/08/14
  • Wiper Blades
08/xx/2022
  • Spark Plugs replaced NGK ILKAR7C10
107,358 2022/08/25
  • Coolant reservoir cap replaced
  • Front brake wear sensor replaced
  • Tire Rotation
107,137 08/12/2022
  • Complete new rear brakes and sensor.
  • Brake Fluid flush
  • Front brakes replaced
105,000 04/12/2021 $39
  • Bonnet Switch Replaced
104,500 30/11/2021
  • air filters LR011593
  • Cleaned MAF sensors
104000 10/12/2021
  • New H8 AGM Battery
  • Bosch Wipers
103,000 09/08/2021
  • Oil Change Mobil1 EP 5/20
  • Replaced rear lift gate actuator
96820 03/16/2021
  • Heat Manifold Tube Replaced
  • Brake Lines Replaced
  • Brake Fluid Flush
  • Cabin Air Filter Replaced
96650 03/04/2021
  • Front Differential Fluid Change
  • Rear Differential Fluid Change
  • Transfer Box Fluid Change
96500 02/19/2021
  • Oil & Filter change
  • Engine Air filters replaced
96136 02/21/2021
  • EAS Tank Replaced
  • Inspection
95,520 01/15/2021
  • Intake Manifold Gaskets LR010881
  • Water Pipe Assy Front LR018275
  • Bleed Plug LR011038
  • Throttle Body Gasket LR011999
  • Coolant
95,372 01/09/2021
  • Serpentine Belt
  • Fan Belt
  • Water Pump
  • Coolant
PREVIOUS OWNER
94,327 11/24/2020 $5247
  • Replaced Transmission, pan, skid plate (?), fluids
92,693 09/15/2020
  • Oil & Filter
90,962 07/28/2020
  • New 255/55R19 Toyo Open Country Q/T 111V XL tires
90,670 07/16/2020 $422
  • Battery Monitoring Sensor LR048601
  • Fuse Holder
90,560 07/09/2020 $1138.00
  • Alternator LR091107
  • Brake Pad Wear Sensor front
90,204 $487
  • Brake Pads front
  • Brake Rotors and Pads rear
  • Brake Pad Wear Sensor rear
87,118 02/14/2020 $297
  • Oil & Filter
  • Transmission Drain & Refill
86,468 01/20/2020 $985
  • Tire Rotation
  • Front Brakes Rotors and Pads
  • L Front Brake Sensor
81,912 08/09/2019 $629
  • Oil & Filter
  • Leak Detection Pump
76,371 03/14/2019 $110
  • Oil & Filter
71,117 10/26/2018 $139
  • Oil & Filter
58,451 09/15/2017 $109
  • Oil & Filter
51,964 02/16/2017 $1310
  • Tire Rotation
  • Control Arms Replaced (front?)
  • Alignment
48,135 09/23/2016 $280
  • Oil & Filter
  • Battery Replaced
38,659 09/25/2015 $821
  • Oil & Filter
  • BG203 Fuel Injector Cleaner
  • Cabin Air Filter LR023977
  • Engine Air Filter LR011593
29,287 09/26/2014
  • Oil & Filter
  • Cabin Filter
  • Fuel Injector Cleaner
20,411 09/17/2013 $475
  • Oil & Filter
  • Cabin Air Filter
12,229 09/18/2012 $475
  • Oil & Filter
5,613 10/22/2010
  • Oil & Filter
mmbirtcher
New front brake pads today. Reinstalled GOBI Roof Rack wind fairing. The Roof Rack sunroof panel has never been used and is in original packaging.
mmbirtcher
Including 3 GOBI awning rack mounts.
Replaced damaged passenger side headlamp.
Installed new hood struts.
Buffed out 99% of light pinstriping.
helge
