2010 LR4 transmission fault
Pablitovil
Panama
did you ever fix it? I have the same problem driving me nuts!!
I have the exact same issue and am trying to confirm if I need a new transmission or its just the mechantronic hoses and sleeves. Mine only slips as the op says, when on a 20% incline. Mine is throwing a code for 5th gear incorrect ratio (P0735-07) as well as P2704-07 Transmission friction element E apply time range/performance (Mechanical failure) The video above seems to say if your getting incorrect gear ratio codes its likely the mechatronic sleeves. However the other code from my research is usually an indicator you need a new transmission or a rebuild. The car drives flawlessly expect going up mountains/steep hills in high gear and the ocassional 2-1 clunk (also video says a sign of bad mechantronic sleeves) anyone have any feedback on these codes?
Jose Aguilar
Mexico City
I also have trouble with the transmission. My codes are:
PBM-Parking Brake
  • U0402-00 (2B) Invalid data received from transmission control module
    ( on 01-05-2021 14:26:38 at 75787 km )
TCCM-Transfer Case
  • U0402-00 (2F) Invalid data received from transmission control module
    ( on 01-05-2021 14:26:44 at 75787 km )
TCM-Transmission 6spd
  • P0915-01 (AF) Gearshift position - circuit range/performance - General failure information - general electrical failure
Would be grateful of your comments.
