Cylinder 8 Misfire
CO-LR4
Colorado
Hi folks,
I did see the other thread with same title, but no recent work done that would have delivered same solution.
Overview: driving 30mph, after depressing accelerator engine shuddered. Flashing CEL, Restricted Performance warning. While driving flashing CEL persists, when come to a stop, the CEL will go steady.
Codes:
PCM-Engine Petrol
P0308-00 (AF) Cylinder 8 misfire detected
P0316-00 (AF) Misfire detected on start-up (first 1000 revolutions)
As isn’t related to either or both banks, leads me to believe something specific to cylinder 8- anyone have similar codes and a path forward?
Planning on bringing to indy shop Monday, but hoping to possibly identify and fix without losing my shirt next week.
Thanks in advance!
CO-LR4
Colorado
Spark plug, coil, fuel injector would all be cylinder specific failures. Any could give these codes and symptoms described.
Plugs done recently (<20k mi), but will check coil before diving into the injectors replacement. Appreciate response! Seems manageable (famous last words).
CO-LR4
Colorado
Haven’t checked all injector and coil connectors but seems a few have a bit of wire exposed near the connectors- will this cause issues down the road? Was thinking just some liquid electrical tape as seems suitable for automotive.
