westcoastrover
Have a 2015 LR4 that is up to date with service and runs fine. The Low Coolant Warning Light just appeared on Dash. The tank is pretty empty. Of course, there are a ton of issues that could have caused this. But best case scenario could it just need to be filled with LandRover OEM Coolant? Before I do costly diagnostics (pressure tests, valve tests etc.) and skip the flush as the Coolant Reservoir is already nearly empty? There is no apparent Leak, on ground, as it is parked in the same spot and not driven much.
Don't plan on driving it more than a mile or 2 on flat paved ground once I fill it.
Aware Coolant could cause serious engine issues. But this could be a good home test before I get housed on perhaps overkill tests and labor hours for repairs that don't end up need to being made.
