Red Top Engine
I rebuilt my engine nearly 5 yrs ago. Had the heads, block, etc checked and replaced everything that could be replaced. Runs and drives great, no coolant loss etc. 2 years later, head gasket failure symptoms presented themselves. so I took it apart thinking the head-bolt threads are wearing out, re-threaded block using NS300L tool, and re-installed heads with new bolts, gaskets etc. 2 years later to the date, leak down test confirms coolant being displaced primarily on cylinder 7, and slightly on 5. I purchased my gaskets from AB, which I believe are OEM. Are there are other gaskets out there that are above OEM specs? What exactly causes these gaskets to fail?
