Long crank, no faults
Adrien
Seattle, WA
Good point, forgot to mention that I’ve been running a trickle charger for the battery
Good to know! Also for your weird voltage issue, have you tried moving your new ground to behind the BMS instead of bypassing it straight to the terminal? The BMS works in mysterious ways
Jimmy Brooks
Pasadena California
I have not yet. By behind the BMS where are you talking about?
Adrien
Seattle, WA
Anywhere downstream (or upstream I guess) of it, basically any other ground than the negative post. Land Rover claims that any accessories or even chargers should be grounded to something other than the negative post because of the BMS, but no one really has an explanation why… so who knows if it actually matters but worth a shot
Jimmy Brooks
Pasadena California
Ok, I’ll move it and see if the car still starts. Also I do have a light bar that was grounded to the negative post when I had it installed, I wonder if that’s messing with the BMS when I used it during night time off-roadside
Adrien
Seattle, WA
Eh, honestly I have my doubts on if it makes any difference. Only reason I say BMS is that we’re clearly getting very strange voltage issues and there’s no charging system fault light. Usually I swear a spec or dust can be on one of the battery terminals and that light comes on
Adrien
Seattle, WA
Battery is charged, about to do the jump cable test. Jimmy for your initial test did you connect jumpers to both of those coil grounds? Or did you start it with just one?
Jimmy Brooks
Pasadena California
I did both on the first test. I had to take another set of smaller cables to get it in the gap of the coolant pipes.
Jimmy Brooks
Pasadena California
New ground set up, car still starts up, voltage is still high and battery is now charging. I might just leave it like this if no one else finds the issue with what makes the resistance high on the regular configuration.
Only thing is one of my MAF Senser’s reads -30 volts which I don’t understand because it works just fine. Gas mileage is good and the car runs fine. Might just leave it unless I start getting a CEL or the car acts up.
Adrien
Seattle, WA
Moving wire upstream of BMS fixed charging?
Waiting for smaller jumpers to arrive to finish the first test on mine, meanwhile I’ve removed the passenger wheel and fender to get at these ground wires and hopefully start making headway on finding the actual culprit
Jimmy Brooks
Pasadena California
Yes it did.
