2013 to 2014 Face Lift Headlight Install
Yes, it will on any year LR4, but you will have to at least replace the grille, too.
Powerful UK has a youtube video on it.
wallyyfm
I now installed the lower valence to fill the gap between the new grille and bumper. Took maybe 90 seconds. I did drill a very small pilot hole and it does fit flush, although it is maybe a little shallow of the grill by a mm.
wallyyfm
Also I did add these morimoto XBs in yellow. At first they seem not all that bright. I don’t need crazy bright ones as I will be installing triple R’s soon. I will update the beam pattern tonight, although I did not see a an aiming mechanism. If these suck I think I will return them.
I was waiting on the 4bangers but they kept going out of stock.
wallyyfm
I went all out on the lazers, was $800 for the kit. If these suck I will try the bajas. Just a little more than I wanted to spend for fogs.
If I was still in the desert I would have….
