jjvd21
- Joined
- Jul 7, 2007
- Posts
- 577
- Reaction score
- 36
Replaced at 52,000 miles in my 2016 the pipe ends were crumbled.
I am currently doing the crossover pipes and water pump in the 2013 at 89K. Pipes look fine, but we shall see what happens when they are removed- I have a small leak at the water pump due to a failed gasket. I am recording as I go, its going to be a rather long video as i am being detailed in the discussion, i will decide later if I really want to post it. Biggest issue is that current online videos are incomplete and its alot of discover as you go, which is very slow. Minor amount of new tools to purchase- now that I figured it out. I keep running into new issues that require additional parts and tools and work. And everything adds days. IF you had all the parts and tools and knew the tricks, i would personally schedule 4 days, but i work slowly. Wizards could likely do it in 2 days. If you can do brakes and if you have ever replaced fuel injectors you can do this. But lots of steps….and because access is tight and challenging its physically demanding due to the body positions…
Did the front and rear crappy plastic pipes on my 2010 V8 at 90k miles. The front crossover and maybe the water pump too showed a small leak over 18 months. It was pooling on the vacuum pump and clearly visible on skid plate upper surface. Overall a straightforward job, if a little fiddly accessing bolts on the rear manifold pipe. Just be OCD in not dropping anything down inlet ports when the manifold cover is off and make sure you follow the correct bleeding procedure after everything is back together. I am an average mechanic. Probably took me 6hrs in total on my driveway.That’s a great piece of mind, I’ve known people who lost their (V8) engines to this issue.
My 2014 V6 here in Colorado is at about 65,000 miles. My local independent said he “looked” at it and it looks ok for now, but I’m not sure I want to trust it much longer.
Do the normally leak a little bit before they blow?
Is this a job for a home mechanic or are there too many steps and specialty tools?
I’ve done rotors and brakes and recently the vacuum cap that made it rev like crazy on every start… that was a bugger to get to.
My locals want over $2k for the job and I think it’s best to add the water pump at the same time?
What advice would you all give?
-Paul
well, they were definitely crumbling. The tech put the pieces that fell off in the box with the parts. Our LR4 has 54,000 on it. So parts were in state of decay at what i would consider low mileage. That said, it is six years old.
Yikes. I was going to do all that cooling system work this fall but ran out of time and was planning on doing it this spring at 8.5 years and ~50k miles. I thought I would be way early. Perhaps not! No signs of leaks, though.
