Just confirming... you are checking for fault codes with a GAP IID tool, correct? Or with a generic OBD-2 code reader?
No codes at all sounds odd. Wild guessing I'd wonder about the crank position sensor, which on some other makes (non-LR) can cause the engine to die after reaching full temp, and not restart until it cools down... then the symptoms repeat. I have no idea if the LR engine/sensors can suffer the same issue or not.
