I note the comment about the scanner calling up some starter fault.
The trouble with all these scanners is I find they generally send you off in the wrong direction. I know that is not nice to say but what you can learn from these scanners is that if you are patient and can get them to tell you a series of differing errors, then often you can figure out the common element.
It you had a starter problem, I tend to think the engine would not start or there would be the clicking thing a number of times before the engine did start. Once the engine is going however, it will keep going and you will be afraid to shut it down - you will not when at the grocery store etc but will leave it running, hope it is still there when you return and if so, at least it will get you back home.
The jpg's below show or attempt to show the starter solenoid contacts that tend to fail and hence either a new solenoid or more commonly, a new starter motor.
Are you getting any odd fluctuations of the gauges on the instrument panel? Fuel or temperature gauges intermittent - that sort of thing.
I ask as there is a single large connector on the rear inboard side of the instrument cluster that feeds not only the gauges but the backup memory chip for the engine computer. The plug tends to loosen in the connector over the years as LR did not make the cable quite long enough and it is always being tugged at. The fix is just to unplug and replug the connector. The clue is that the gauges tend to act odd or just not read.
Getting to the rear of the instrument cluster is not so easy but once there, the unplug / replug thing is easy.
I mention this as that not quite connectoed connector can be a real show stopper, as in there is nothing - no lights etc - like the battery has been removed - everything is dead - well maybe the interior lights work but that is about all.
The 3 basically will not run without the backup memory chip and that is also the reason you cannot swap instrument clusters with another similar vehicle - the VINs must match.
The link below to how to remove the instrument cluster on a Sport - the 3 is similar and I expect there are YouTube videos specific to the 3.
The doc attached talks about the instrument cluster and the CCF, Car Configuration File and how the chip within the cluster must communicate with the Engine Control Module and the Central Junction Box - this is a real committee affair but must be 3 out of 3, not 2 out of 3 as is often how this stuff works - like say when guys rocket off to the moon.
