Installing Running Boards
DonC
The Woodlands, TX, US
No need to jack up the vehicle but you will need to drop the plastic sill covers to cut some plastic out. This will allow the brackets to pass through and attach from the body to the running board. Not bad and it is already marked where to cut on the inside of the plastic sill cover.
Kuro50
NJ
Luckily I think my cutouts are already present from the old set!
Is it possible to get the tools needed at any local Autozone or Advanced Auto parts?
anyone have a good resource they can point to for an installation guide? Thanks ahead of time!
DonC
Powerful UK has a video on the install procedure. Since you already have the sills cut it should be a really straight forward install.
as for the tools it requires just basic tools so you could get them anywhere.
Kuro50
NJ
The dealer did. I’ll keep you all posted on my progress (or lack off)
Any must have mods, accessories or update that anyone can recommend?
Kuro50
NJ
Thanks!
PE_in_UAE
