douglastic
- Joined
- Jan 26, 2016
- Posts
- 168
- Reaction score
- 52
Hi all,
I've seen old threads with mixed reviews on whether or not the oil can be sucked out of the LR3's dipstick hole by a Mityvac or equivalent extraction system....has anyone successfully done this? By successful I mean all 8 quarts or close to it....Thanks in advance.
-Houm
Is the goal avoiding a buggered drain plug?
Not being under the vehicle?
Not dropping the skid plate?
If you can get most oil out with a mityvac, you could just change more often so the residual mix diluted quicker.
But you still have to get underneath to change the filter, so I am not sure I understand the benefit of oil extraction vs draining.
Can you explain what your perceived benefit would be in your case?
I have the stock skid and don't mind going under for a traditional change.
It also gives me the chance to look around at many wear items that typically go unnoticed until you actively inspect.
