Interior lock button
Jonathan Reed
Crystal Lake IL
Sorry to bring up a older post. Just know that many of the 2014 and later models did not come with the memory module. I installed the buttons in the door and nothing. Looked under the seat, no memory module. Not clear on initial inspection that the existing wiring harness can connect to the memory module if I were to acquire one. If anyone has completed this retrofit, without a pre-installed memory module, please share how you did it.
I'm not 100% sure if this is required, but isn't there a setting on the CCF? I've seen the memory option on the IID GAP tool, but I don't have the module (my cars also a 2013)
Jonathan Reed
Crystal Lake IL
I went to the GAP web site and found this in the CCF list for 2015 LR4. Looks like I'm getting the tool. . .for this and many other reasons. Just wish it worked with Discovery 2.
Memory functionality • Undefined
• Without memory
• With memory
Memory seat movement • Not fitted
• Fitted
Jonathan Reed
Crystal Lake IL
I received my GAP IID Tool yesterday, ran out to the 2015 LR4 and enabled the memory seat module in the car's CCF. Still doesn't work, so I switched it back. As I stated earlier, when I looked under the seat, I did not find the memory control module. So I am hoping that the only thing I'm missing is the memory control module.
Now, doing some searching through the Land Rover parts catalog, the power seat switch (all of them) have the "with memory" option. So I suspect that the wiring loom for the memory control module is on that lead. I first need to acquire a cheep used memory control module.
rt10516
Lacey, WA
Hi All,
I tried to add the seat memory to my 2014 LR4 HSE, which has the memory module under the driver's seat and it's not working. With my GAP tool I changed the Memory functionality to "With memory" and Memory seat movement to "Fitted." Does anyone have any other ideas why this might not be working?
To test I did not fully re-assemble the door trim panel. I did connect the two main wire harnesses to the door panel and of course the connector to the seat memory/door lock switch, but since I did not clip the panel back onto the door I was not able to fully close the driver's door. Does it need to be closed for the seat memory switch to work?
Any ideas would be appreciated.
Thanks
eli4x4
New Jersey
Hi All,
Thanks
Can you post pictures of the module and wires?
rt10516
Lacey, WA
It's difficult to get a good picture of the module. Also attached is the wiring diagram provided by GAP. I contacted them about this issue. He said I do not have the DSM (Driver's seat module) ECU installed from GAP: "You need to purchase the correct part, ECU and install it physically. Else, you may have a wiring, fuse or other issue to address.
Good luck
  • Memory Seats wire diagram.pdf
BriComp
Arizona
Ha. So for a 2015 HSE we need to purchase an ECU from GAP and load it, the door buttons, and a memory module?
