scott schmerge
that’s to have my independent do the valve cover replacement and gaskets. Felt reasonable to me for a Land Rover oem and labor...no?Holy cow. I hope you can figure out a source that's cheaper than that.
Silver lining #2. Timing chains checked by tech once the valve cover was off (at 120k on the clock) and all tight...Found my issue...cracked the damn valve cover tab on the pcv valve. $1400 mistake. Careful. That plastic is brittle! I needed a new valve cover anyway...rhs was leaking oil...so there’s a silver lining.
I really need to get with you on scheduling for my Rover to spend a week with you....Just let me know what works on your end. You offer a loaner car don't you?![]()
Found my issue...cracked the damn valve cover tab on the pcv valve. $1400 mistake. Careful. That plastic is brittle.
Sorry, late reply. I'm into older vehicles like the 95 D1 (OBD1), I can work on and play with without stealership assistance. Able to read fault codes, repair and reset to blank. Only fault I get once or twice a year is a 048 "stepper motor idle too low". My fault with setup having a low cold start idle forgetting leaving the AC one. Only a 20 second fault code clear.
Not a clue or interest in newer LR's especially after the adventure helping a friend with replacing 5.0 heads we got dirt cheap frfom Pick-n-Pull. No thanks the old push rod motors are simple, fun, easy to work on and can run 2-300K trouble free miles. No timing chain or coolant failures.
I see you have a collection of vehicles. At this end 54 VW w/56 Speedster engine, trans and the big aluminum brakes. A 56 Mercedes 300c the big sedan, 69 912 Porsche (wifey's car). 68 F250 Camper Special w/454, 427 FE block w/428 crank, 427 medium riser heads, it runs strong a fun sleeper. All Ford no chubbies at this household. A 81 DMC in storage 314 original miles original owner. Nobody including the wifey drives my vehicles, no loaners available. The trick is playing and adding performance but still passing smog checks. Best reward is having the D1 running my way now a more flexible engine than factory ever dreamed of producing, talking 87 to 95 D1's and not that sad 3.9 gutless engine either......~~=o&o>.....
Well your post did start me pondering running a pre-oiler, bypass oil filter, and adding a catch can on the intake side.
Agreed on the cheap parts. It's thought provoking on how robust some elements of these vehicles are and how dollar store cheap some elements are.
