scott schmerge
Scott, once again big mahalo for your help! ill get to this today and post my experience and results.
Went to the LR dealer and bought the sensor since i figured i do both jobs at the same time just incase. fairly straight forward. i didnt disconnect the 2 hoses going to the throttle body as i was able to clean everything needed. Suffice to say, it was black as nite in thereFollowed your steps with the GAP tool and started the engine up. MUCH better!!!
Now to figure out the weird vibrations when i turn left...
Glad to hear it. Your vibrations could be a couple things. Start with wheel bearing check and a look at you cv joints on your half shaft. Could be either. If I’m not mistaken, some people report when a wheel bearing is going bad, the sound actually comes from the opposite side of the way you are turning (the wheel that gets the most weight). For safe measure, check both. And only go with a Timkin bearing, if that’s it. Easy change.
Lots of info on both bearings and half shafts on here to reference. Good luck!
