Turn Signal!!!?
pat955
Has anyone changed the turn signal bulb before, what bulb type is it??:confused:
Which one, front, side repeater or rear? The rear ones are LEDs and I don't believe they are user serviceable. Specs (and removal instructions) for front and side repeaters' bulbs should be in your manual.
Lone Star landy
On the front or on the side?
Front- PY 24W
Side- WY 5W
From the owner's manual.
Tdawg183
Raleigh, NC
I'm having some trouble figuring this one out too. My manual says its a PY 24W for the front but any of the PY24w bulbs i've tried do not fit.
The first image here is a PY24w
The second is what my bulb actually looks like.
You can see they're close but the actual bulb has a much longer stem.
Is there a bulb model number on the bulb you removed?
Slytrellis
