2011 lr4 hd radio problem
Blkrover1111
North hollywood
Hi guys I have a problem with the radio any help would be great the problem is that when I go on to the radio settings there is an option to turn the HD radio on and off mine is stuck on off when i press on it won't change i tried the following did a hard reset with the battery that did not work went in the control module with the iid tool and checked no faults and it shows that it is is equipped anyone knows what the problem hight be
jaguardoc504
Possible you do not have the HD radio module fitted.
I get incorrect fitted/not fitted errors on a few different modules when the CCF is pulled.
ZR1Gerhardt
I had to use my IID tool to log into the computer and tell it that I had an HD radio. After that, it always worked. You might have to have LR log in and change it. They might charge and arm and a leg just to do that though!
Scott
LR4HD
california
I have the same problem. I have a 2011 LR4. My HD radio worked until a few months ago. I was driving and the HD radio just stopped working. When I go to the settings menu I'm unable to turn it on; it is stuck in the "off" position and when I press "on" it stays in "off" position. I tried the hard reset by disconnecting the battery but that did not work.
I'd appreciate any help with this problem too. If you find a solution BLKrover1111, please let me know. I'll do same.
quirozson
Denver, CO
Bump. I’m having the same problem with my 2011 LR4. A month ago I got it to turn on but it had pretty inconsistent reception. I’m thinking that there must be a loose antenna wire somewhere. Does anybody know where there are potential loose connections for an HD radio antenna? I live in Denver, and my Volvo gets excellent HD reception.
Cthehentz
Las Vegas
My HD radio works great, it’s the satellite Sirius that drives me nuts, cuts in and out driving around town, I install an after market in my LR3 that works flawlessly. Is there a antenna upgrade for the LR4?
Do you have a roof rack? Some racks play hell with the sat reception
Ha, actually I do have a roof rack.
I'm curious which one.
I started with an Thule basket on mine, and that caused sat reception to cut out intermittently for years. Somewhat related to time of day, it seemed.
I replaced the Thule with a Prospeed, which has a cut-out for the antenna. No issues with sat reception since that change.
