Whining from the engine Whats going on? What part do I need to replace?
roverca
San diego
When I hit the gas there is a loud higher pitched whining from the engine. Also noticed my oil was lower than normal and found a leak see picture. Also, if I take the old dip stick out there is a air hissing sound and if I remove the oil cap the engine stalls. 2007 V8 LR3 with 95k miles
Gnomad
Harbor Springs MI
Your engine is set up to scavenge and burn oil and crankcase vapors, removing the oil cap and dipstick allow unmetered air into the engine and cause the symptoms you describe, that is normal operation and not a problem, as long as you don't drive around like that!
roverca
San diego
Haha. Ok cool thank you! I didn't know that the engine would stall when you opened the oil cap. The higher pitch whining when the engine rpms go up I'm not understanding and the leak of oil.
catman
A worn belt and/or pulley or a failing alternator will often make high pitch whines - you might check those. I am not sure if the whine and oil are related, you may have 2 distinct issues.
scott schmerge
Charlotte, NC
When I hit the gas there is a loud higher pitched whining from the engine. Also noticed my oil was lower than normal and found a leak see picture. Also, if I take the old dip stick out there is a air hissing sound and if I remove the oil cap the engine stalls. 2007 V8 LR3 with 95k milesView attachment 9214
Looks like your PCV valve to me. That is what allows gasses built up in your crankcase to vent back into the intake. Inexpensive repair.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/233087751577
roverca
San diego
Landed in the same place and ordered the PCV valve today. I hope that works.
roverca
San diego
belts looked good and I already experienced an alternator that I replaced a year ago. I hope the PCV valve is the ticket.
HarryO
I had a similar noise - thought it was the alternator or water pump. Had it checked out - took two rounds for them to find that it was the Airconditioner compressor making the noise because the gas was low - easy cheap fix once they found it...
That is a very different whine than the alternator....
