How are roof rail nuts/thread secured?
RON8O
I’ve got a troubled bolt broken off inside one of these roof rail nuts (what are these called anyway?) and it’s not budging, even after quite a bit of work with various bolt extractors. I’m wondering if it would be easier to replace this nut, take it to a shop and have them cut it off and weld a new one on, or possibly drill this out and rethread it.
Anyone know how these things are secured to the roof? I can only see a bunch of softish substance surrounding it, which I believe is to prevent leakage to the interior.
Any tips are appreciated,
Ron
Frank8
Vermont
Try penetrating oil first. Put a few drops in every day for a week or two. Patience is necessary for penetrating oil!
I use Kroil penetrating oil. It’s the best stuff I’ve ever found.
If you can get purchase with an extractor it’s only the rust and crud holding it in and the Kroil will deal with it.
johnnwalters
Hey, I may be too late on this but were you only removing the trim piece to put on a roof rack? In that case those original pieces were plastic and can be pulled out with tweezers. If not then go through the steps above.
Pfunk951
I broke off a bolt in one of these.. CAREFULLY drill it out with an opposite direction drill bit, mine came out about halfway down. PB blaster the hell out of it, let it sit, and get drilling..
You can have someone cut it out and replace it, but I think that's a last option.. These channels get a lot of rain, and if you start getting rust up there things are going to go downhill fast..
Good Luck!!
RON8O
It’s not the plastic plugs that are the issue now, but mine were so sun damaged that only a few of them came out without breaking. I tried unscrewing them, etc, but they were just too brittle. After a lot of messing with them, I did finally get the plastic pieces out.
toddjb122
Yes drill it out. I've changed out my rails several times and always add a little lithium grease when re-installing the bolts.
That's a great idea. I wish I would have done that when installing my rack!
