Over the weekend I moved my trusty Llams height controller from my "outgoing" RRS to my new LR4. The transfer was no fun (especially removing the wiring harness off the RRS, those sockets seemed to be glued to the EAS control module, and that sucker's not easy to work on to begin with), but a couple of hours of swearing, pulling, sweating, drilling and calibrating later, the module and control switch are successfully installed in my new baby.
Photo of the location of the rotary switch and LED (on the lower steering column shroud, opposite side of the electric steering switch and about a 1/2" above the "emergency" sensor for the fob transponder.) I am used to operating that 4-position switch by feel after a few years of practice on the Sport, so no need for me to mount it on the center console to replace the cigarette lighter socket in front of the TR controls like other LR4 owners have done. I can use all the 12v sockets available, would have hated to lose one of them to the switch...
For those not familiar, the Llams height controller is an electronic module that allows you to modify the stock height of your EAS suspensions on-the-fly on 2005+ LR3 / LR4s and RRS by turning the 4-position switch mounted in the car: -20mm, off (stock height), +30mm or +50mm. These changes are not speed dependent and are on top of the height changes provided by the "regular" EAS settings. I've used it for almost 2 years on my 2006 Sport and it's been performing great off-road and on. Not cheap but worth every penny to me.
