churious
- Joined
- Nov 14, 2008
- Posts
- 340
- Reaction score
- 35
The positive battery cable is a long thing, but the negative, (part # YTB500063 for the LHD)I would say not even 18" in length. It starts at the negative post on the rear of the battery closest to the firewall and runs to a threaded stud welded to the inside surface of the right side fender interior metal.
There is also a second ground strap, (part # YTB500122 for the 4.4 petrol V8), installed between the engine and chassis somewhere under there but I do not know exactly where.
It is also possible that there is nothing wrong other than too many short trips. In the winter, I routinely put my CTEK Multi US 3300 charger on every night for a week or so every couple of months. These CA CA batteries just do not fully charge in cold weather as they need about 14.6 volts or so to get fully charged. The CTEK's provide about 14.7 VDC on the Snowflake setting. I think that NAPA charger you show in the jpg does the same thing - it looks like the good one and has an AGM setting which is OK for the Interstate CA CA battery in the winter.
I think you will find the 3 floats at about 14.1 VDC when all is happy but somehow cannot or does not quite charge the Interstates in cold weather with short trips.
Could just be short trips. I only live 6.5 miles from my office so its a short trip back and forth.
