A friend stopped by with his 96 D1 w/105K miles, the ABS has gone off at slow speeds, backing out / in driveways. There is around 1/8" play at the top of the right front tire when shaking in and out. This is not from the swivel pin or swivel bearings top and botton, all from a loose wheel bearing.
Question, will this allow the ABS sensor ring to move away enough from the sensor and cause the ABS to go off? The left swivel and wheel bearings are tight or zero play. Rear wheel bearings tight and all 4 wheel sensors have been reseated.
.....=o&o>.....
.....=o&o>.....
