What did you do with your Lr4 Today?
Does the 4x4 screen on your satnav show any wheels going crazy?
I guess I only wrench on holidays.
This weekend I did a couple of odd jobs and fixed something that popped up.
When I did my spark plugs over Thanksgiving, I noticed while reinstalling a coil on the passenger side that the electrical connection did not "click" when plugging it in. I removed that coil again and saw that the plastic nub on the coil that would hold the electrical connection in had somehow broken off. I used a UV glue pen to put a little ball in that spot, then used a razor blade to give it a sharp edge that the electrical connecter could latch onto. I knew that fix was temporary, though, and replaced it with a new coil this weekend. The glue was still holding up, but that coil will just be an emergency spare for now. Unfortunately, the coil was the second one from the back, which required me to remove the battery box again.
I also replaced both of my PCV valves. No sign they needed replaced, but I figured since I just crossed 100k miles it would be good preventative maintenance. While the caps were brittle and the tabs broke off, the rubber valves themselves were still perfect. Probably didn't need to be done at all. But at least I won't worry about it needing to be done anytime soon.
While on the road this weekend, got a CEL for a driver-side MAF sensor. Hit it with some MAF cleaner (and made sure all the intake hoses were clamped tight) and it cleared it right up.
Michael Gain
Clarksville, TN
I can relate. This long weekend SHOULD allow me to replace both exhaust manifold gaskets, motor mounts, and the thermostat. Cooling fan hasn't shipped yet, but that will follow pretty closely---this is all assuming my wife's to-do list has not grown in the last 15 minutes.
LR4inAZ
I changed the front Air Struts - lots of fun!
I have a 2011... air struts I took off were 2016... interesting since dealer never told me they were replaced at any time...
hopefully they last longer than 5 years
Michael Gain
Clarksville, TN
So...about the exhaust manifold gaskets... I think I'll let an Indy replace those.
Well, I started on the driver-side since it would be the hardest. Topix printouts were helpful, but did not convey how limited the space actually is. Basically, everything is in the way on the driver side: front diff, steering shaft, a/C compressor, and power steering pump.
I took off all of the heat shields behind the upper control arm, but still had no access to the actual manifold heat shield bolts. Valve cover makes it impossible from the top. Front diff makes it impossible from the bottom.
I think, if I had a lift, it would be easier to come in from the sides: remove power steering pump, a.c. compressor, and motor mount; but laying on the floor didn't work out.
I put everything back together and started my wife's to-do list.
Troy A
San Francisco, CA
Took ours out to Hollister Hill OHV park the other day to crawl around and see how the pup handled being in the truck on rough trails. No vomit so that was a win. Only did the blue trails. Didn't attempt all of Truck Hill as the sand was pretty damp and slippery. My Cooper ST MAXX were not great on anything wet and muddy even down at 33 psi.
LR4inAZ
Looks like fun - who gets sick first? Dog or you? :)
