Weird NAV system behavior
Hi all,
Just completed a ~1000 mile trip in the LR3, a little bit of mild off-roading to get to a campsite but mostly mountain highway and a lot of climbing/descending over passes.
On the return trip, my NAV system continuously turned off momentarily and would take me back to the "Lawyer Statement" and after accepting it, go back to the route. Then after about 4 of those cycles, I turned it off. After 10 minutes I turned it back on and this time I had to re-enter the route because not only was the guidance lost but ALL stored points were GONE. My "home" location, all points I'd saved in various off-roading trail systems....everything.
The rest of the trip it worked fine though...you know, aside from labotomizing itself. Anyone seen anything like this?
jwest
Seattle WA
I've never seen or read of anything like that. It's probably a self-destruct program to get you to go buy a newer dvd set ;)
tlt
It sounds like you have an intermittent connection. Perhaps start at the rear of the unit and check all connections.
...something tells me I'll never get my manually-entered points back yet though. That's what kills me the most. I painstakingly found each trailhead by looking at the zoomed-in NAV map and comparing it to a paper trail map, then named them so that I could use voice commands. Oh well...I guess it's an excuse to drink beer and re-enter them.
schwaggy
At least yours save. I can enter points, destinations, even Home and Recents.
**** - all gone after 36 hours give or take a few.
Any ideas on that???
No idea...but I bet there is some kind of ECU that is the culprit!
