Water pump replaced, still leaking coolant
Lgibson
I would climb up on the engine, reach back to the rear heater manifold pipe and feel for coolant slime, even though it is new. Ours has been oozing for 6 years now, about a pint every 3 or 4 months, not enough to drip but I can see the orange stain way back along the ******. Bought a new manifold pipe but am waiting for front crossover or water pump failure to make it worth my while.
I wouldn't wait for a front pipe to fail. If the front pipe fails and you don't shut the engine down immediately, you'll have a pretty easy time replacing the rear crossover while you're doing an engine swap.
Bad pump? I had one fail in less than 3k kms and a month after install....
Mozambique
toronto
Replaced it in August along with the front crossover. The original leak was from the crossover pipe seals
Lgibson
Yes, I heard that.
My pipe just seems to ooze along its length. It must tbe porous in some way. The seals are fine.
Mozambique
toronto
Does it have a seam along its length; I forget? Either way, if it catastrophically fails, big problem; I would replace sooner rather than later
