Water Leak in 94 Disco
healey1006
I just acquired a 94 Disco. After washing it, I noticed a puddle of water on the front floor mats. I found that when water is sprayed in the area where the windshield wipers are located, water eventually leaks from under the lower dash area on both the driver's and passenger's side. Is this a case of a clogged AC drain line or is there another drain that is clogged?
That sounds more like a leak.... hmmmm sorry no pun intended. You may very well have some rust issue or a possibly a vent issue...
It could be the A/C drains since water will get into the vents and then to the drains, you can always climb under and check them... but if they are not clogged, you may have a new issue I haven't seen or heard of... not that I am all knowing.
98GRDisco
I used de-icer to unclog the AC if that is the problem
gvillalongo
